Originally posted by: uiowa_edu
Hi,
I'm encountering strange solution time results when solving a SOCP portfolio optimization (see below). Specifically, when I solve for 50 assets and 2500 randomly generated scenarios, the solution speed is much slower than for 50 assets / 5000 scenarios, which should not be the case as the latter is a much larger problem. For example, solution times averaged over twenty instances were 48.3 seconds for 50/2500, while 50/5000 solved in only 5.8 seconds. The problem is formulated as follows (I'll be happy to provide my code if anyone would be willing to look at it):
min: g + (1-a)^-1 * t
st: t >= (w_1^2 + ... +w_S)^2
w_s >= sum (a_is x_i) - eta, s = 1,...,S
sum( x_i ) = 1
expected return >= constant
x, w, t >= 0, g free
a_is = return for asset i in scenario s
Below is a sample pre-solution output for both cases. Notice the much larger "Total FP ops to factor" for the 50/2500 instance.
50 assets / 2500 scenarios Tried aggregator 1 time.
Reduced QCP has 5052 rows, 2553 columns, and 132650 nonzeros.
Reduced QCP has 2 quadratic constraints.
Parallel mode: none, using 1 thread for barrier
Number of nonzeros in lower triangle of A*A' = 12627601
Using Approximate Minimum Degree ordering
Total time for automatic ordering = 1.40 sec.
Summary statistics for Cholesky factor:
Rows in Factor = 5052
Integer space required = 7552
Total non-zeros in factor = 12633878
Total FP ops to factor = 42011105730
*50 assets / 5000 scenarios *
Reduced QCP has 10052 rows, 5053 columns, and 265150 nonzeros.
***NOTE: Found 53 dense columns.
Number of nonzeros in lower triangle of A*A' = 5000
Total time for automatic ordering = 0.00 sec.
Rows in Factor = 10052
Integer space required = 10052
Total non-zeros in factor = 15052
Total FP ops to factor = 25052
I've also encountered this behavior in problems with different numbers of assets. Does anyone have any ideas why a smaller problem consistently requires MUCH more computation time? Is there anything I can do to fix this? I tries all qp solution methods, but non fixed the problem.
#CPLEXOptimizers#DecisionOptimization
