Decision Optimization
Delivers prescriptive analytics capabilities and decision intelligence to improve decision-making.
#Analytics
#DecisionOptimization
  • 1.  A minimisation problem with max{0,..} in objective to maximisation problem
    Posted 08/05/15 09:43 AM
    Originally posted by: Marjoo
    Hi everyone. I hope this is the right forum to ask this question.
    I have a minimisation problem with two conflicting objectives, which both have a weight. For simplicity lets consider the objective: minimisation (weight (sum over max{0, value1-value2}) + (1-weight) sum value2) subject to several constraints.
    Hence, if value2 exceeds value1, the first part should be zero. Otherwise, it should be equal to value1-value2. To force this, the optimisation problem is rewritten as: minimisation (weight (sum over variable) + (1-weight) sum value2), subject to variable >= value1-value2, variable >=0. Hence, the variable is either be zero or has the positive value value1-value2.
    However, now I want to make a maximisation problem out of this. Simply minimising the negative objective results in an unbounded solutions, as the variable can increase as much as it wants. How can I again assure that if value2 exceeds value1, the first part is zero; otherwise, it should be equal (so not greater than!) to value1-value2?
    Thanks in advance!
    #MathematicalProgramming-General
  • 2.  Re: A minimisation problem with max{0,..} in objective to maximisation problem
  • 3.  Re: A minimisation problem with max{0,..} in objective to maximisation problem
    Posted 08/08/15 05:48 AM
    Thank you, I believe that this indeed made me rewrite it. However, now I do have a non-linear problem, and I'll have to see if that will be a problem.
    Nevertheless, thank you!
