PowerVM
Expand all | Collapse all
Disabling USB port in Power HW / HMC
  • 1.  Disabling USB port in Power HW / HMC
    IBM Champion
    Posted Wed February 23, 2022 06:27 AM
    Hi,
    Bumped into curious thing in one security audit.
    Auditors requested evidence for "Restrict physical ports (for example, USB) as appropriate"
    To be honest, I am not really sure what to answer on that one yet; I know USB ports are seen on HMC as standard IO adapters, but never before needed even
    to consider how to disable those.
    Any ideas? Or any official statement in documentation saying something about USB ports in Power? :-)
    Br,
    tommi
    Tommi Sihvo, Lead Service Architect
    TietoEVRY, Compute Services
    email tommi.sihvo@tietoevry.com mobile +358 (0)40 5180 Finland
  • 2.  RE: Disabling USB port in Power HW / HMC
    Posted Wed February 23, 2022 09:17 AM
    Hello,
    This should help you.
    From the ASMI menu log in as the admin user, then expand the System Configuration menu, expand Security and select USB Policy.  From here you can enable or disable USB access on the FSP and on the CEC.
    Regards,
    Douglas
    Douglas Gibbs
    IO Product Manager, IBM Cognitive Systems
    IBM Canada Ltd.
    905-413-5334
    "Tommi Sihvo via IBM Community" ---02/23/2022 06:27:31 AM---Hi, Bumped into curious thing in one security audit.
  • 3.  RE: Disabling USB port in Power HW / HMC
    IBM Champion
    Posted Thu February 24, 2022 02:55 AM
    Excellent!
    This is exactly what I was looking for, Many Thanks Douglas! :)
    Br,
    tommi
  • 4.  RE: Disabling USB port in Power HW / HMC
    IBM Champion
    Posted Thu February 24, 2022 08:33 AM
    Hello
    we cannot find a way to disable USB on P8 .
    Where can i disable USB on P8 machines e.g. E880 ?
    Thx
    vince
    Vincencio Michaelis
  • 5.  RE: Disabling USB port in Power HW / HMC
    Posted Thu February 24, 2022 08:55 AM
    On Thu, Feb 24, 2022 at 01:32:55PM +0000, Vincencio Michaelis via IBM Community wrote:
    Don't assign the USB controller to any LPAR.
    Once that's done, the only other vector would be the firmware update
    that can be performed by USB. Please share if you find a way to
    disable that.
    Would a locked cabinet answer their question?
    Russell Adams Russell.Adams@AdamsSystems.nl
    Principal Consultant Adams Systems Consultancy
    http://adamssystems.nl/
  • 6.  RE: Disabling USB port in Power HW / HMC
    IBM Champion
    Posted Thu February 24, 2022 08:57 AM
    hi
    i know not to assign to a partition but this is not clsoing my security risc here...i want to disable simply by firmware FSP
    Vincencio Michaelis
  • 7.  RE: Disabling USB port in Power HW / HMC
    Posted Thu February 24, 2022 09:05 AM
    On Thu, Feb 24, 2022 at 01:57:26PM +0000, Vincencio Michaelis via IBM Community wrote:
    I'm trying to understand why this is a risk.
    POWER systems aren't a desktop running Windoze which can be infected
    by common viruses which might be written to random USB
    sticks. AIX/VIOs doesn't even read common filesystem types.
    The only security vector I can see is the USB firmware update
    option. That requires signed firmware files so it's a fairly low risk
    and exotic vector.
    Please let me know if you find a way to disable that. Perhaps there is
    an option in the FSP interface, because I've never seen anything on
    the HMC.
