Hello Matt!
Month ago i updated FW from 940 to 950 on 9080-M9S with 4 nodes (CEC) server and this code C1C3C213 hanged more than 1 hour.
Alexey Malchenko
Original Message:
Sent: Thu May 19, 2022 03:25 PM
Subject: C1C3C213 LED code after Firmware Update - FW950.40 (99) - Thought SBE update was only for FW950.10 and before?
I'm getting this LED code C1C3C213 after upgrading to FW950.40 (99) the system was FW950.30 (92) before - The LED Code hasn't gone away and its been about an hour. I thought this was updated only if my code was older than FW950.10?
https://delivery04.dhe.ibm.com/sar/CMA/SFA/0airx/0/01VL950_099_045.html
Power 9 servers contain SBEs (Self Boot Engines) and are used to boot the system. SBE is internal to each of the Power 9 chips and used to "self boot" the chip. The SBE image is persistent and is only reloaded if there is a system firmware update that contains a SBE change. If there is a SBE change and system firmware update is concurrent, then the SBE update is delayed to the next IPL of the CEC which will cause an additional 3-5 minutes per processor chip in the system to be added on to the IPL. If there is a SBE change and the system firmware update is disruptive, then SBE update will cause an additional 3-5 minutes per processor chip in the system to be added on to the IPL. During the SBE update process, the HMC or op-panel will display service processor code C1C3C213 for each of the SBEs being updated. This is a normal progress code and system boot should be not be terminated by the user. Additional time estimate can be between 6-10 minutes.
The SBE image is only updated with this service pack if the starting firmware level is less than FW950.10.
Matt Geisler
