WebSphere Application Server & Liberty
Expand all | Collapse all
WAS datasource test connection fails withjava.sql.SQLRecoverableException: IO Error: General SSLEngine problem after upgrading from WAS 855 to WAS90
  • 1.  WAS datasource test connection fails withjava.sql.SQLRecoverableException: IO Error: General SSLEngine problem after upgrading from WAS 855 to WAS90
    Posted 04/02/21 09:27 PM
    We recently upgraded our WAS from 8.5.5 to WAS 9.0. The datasource test connection
    from adminconsole fails with the following error:DSRA8201W: DataSource Configuration: DSRA8040I: Failed to connect to the DataSource XXX. Encountered java.sql.SQLRecoverableException: IO Error: General SSLEngine problem, connect lapse 0 ms., Authentication lapse 0 ms. DSRA0010E: SQL State = 08006, Error Code = 17,002.
    at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:794)
    at oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java:688)
    at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:39)
    at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:691)
    at oracle.jdbc.pool.OracleDataSource.getPhysicalConnection(OracleDataSource.java:384)
    at oracle.jdbc.pool.OracleDataSource.getConnection(OracleDataSource.java:273)
    at oracle.jdbc.pool.OracleDataSource.getConnection(OracleDataSource.java:198)
    at oracle.jdbc.pool.OracleConnectionPoolDataSource.getPhysicalConnection(OracleConnectionPoolDataSource.java:140)
    at oracle.jdbc.pool.OracleConnectionPoolDataSource.getPooledConnection(OracleConnectionPoolDataSource.java:86)
    at com.ibm.ws.rsadapter.DSConfigHelper$1.run(DSConfigHelper.java:1273)
    at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5488)
    at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5614)
    at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255)
    at com.ibm.ws.rsadapter.spi.ServerFunction$6.run(ServerFunction.java:567)
    at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
    at com.ibm.ws.rsadapter.DSConfigHelper.getPooledConnection(DSConfigHelper.java:1288)
    at com.ibm.ws.rsadapter.DSConfigHelper.getPooledConnection(DSConfigHelper.java:1196)
    at com.ibm.ws.rsadapter.DSConfigurationHelper.getConnectionFromDSOrPooledDS(DSConfigurationHelper.java:2076)
    at com.ibm.ws.rsadapter.DSConfigurationHelper.getConnectionFromDSOrPooledDS(DSConfigurationHelper.java:1952)
    at com.ibm.ws.rsadapter.DSConfigurationHelper.testConnectionForGUI(DSConfigurationHelper.java:2820)
    Caused by: java.io.IOException: General SSLEngine problem, connect lapse 0 ms., Authentication lapse 0 ms.
    at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:790)
    Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
    at com.ibm.jsse2.C.z(C.java:532)
    at com.ibm.jsse2.ap.b(ap.java:476)
    at com.ibm.jsse2.ap.c(ap.java:112)
    at com.ibm.jsse2.ap.wrap(ap.java:277)
    at javax.net.ssl.SSLEngine.wrap(SSLEngine.java:21)
    at oracle.net.nt.SSLSocketChannel.wrap(SSLSocketChannel.java:490)
    Caused by: com.ibm.jsse2.util.h: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
    java.security.cert.CertPathValidatorException: The certificate issued by CN=xxx Root CA is not trusted; internal cause is:
    java.security.cert.CertPathValidatorException: Certificate chaining error
    at com.ibm.jsse2.util.f.a(f.java:21)
    Caused by: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
    at com.ibm.security.cert.PKIXCertPathBuilderImpl.engineBuild(PKIXCertPathBuilderImpl.java:422)
    at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:268)
    at com.ibm.jsse2.util.f.a(f.java:153)
    ... 128 more
    Caused by: java.security.cert.CertPathValidatorException: The certificate issued by CN=xxx Root CA is not trusted; internal cause is:
    at com.ibm.security.cert.BasicChecker.<init>(BasicChecker.java:111)
    at com.ibm.security.cert.PKIXCertPathValidatorImpl.engineValidate(PKIXCertPathValidatorImpl.java:199)
    at com.ibm.security.cert.PKIXCertPathBuilderImpl.myValidator(PKIXCertPathBuilderImpl.java:749)
    at com.ibm.security.cert.PKIXCertPathBuilderImpl.buildCertPath(PKIXCertPathBuilderImpl.java:661)
    at com.ibm.security.cert.PKIXCertPathBuilderImpl.buildCertPath(PKIXCertPathBuilderImpl.java:607)
    at com.ibm.security.cert.PKIXCertPathBuilderImpl.engineBuild(PKIXCertPathBuilderImpl.java:368)
    Caused by: java.security.cert.CertPathValidatorException: Certificate chaining error
    at com.ibm.security.cert.CertPathUtil.findIssuer(CertPathUtil.java:316)
    at com.ibm.security.cert.BasicChecker.<init>(BasicChecker.java:108)
    #Support
    #SupportMigration
    #WebSphereApplicationServer(WAS)
  • 2.  RE: WAS datasource test connection fails withjava.sql.SQLRecoverableException: IO Error: General SSLEngine problem after upgrading from WAS 855 to WAS90
    Best Answer
    Posted 04/02/21 09:28 PM
    Certificate chaining error can occur if the root and intermediate certificates are missing in the cacerts keystore.
    You will need to use ikeyman or keytool to add this intermediate certificate under the signer certificate of cacerts.
    If you have an intermediate certificate, then please see the example below on how to add the missing certificate to the keystore:
    keytool -import -file c:\intermediate.cer -alias intermediateCert -keystore WAS_INATALL_ROOT\java\8.0\jre\lib\security\cacerts
    #Support
    #SupportMigration
