#TechXchangePresenter
Problem building Mobile Designer Project using JDK 6
  • 1.  Problem building Mobile Designer Project using JDK 6
    Posted Tue May 14, 2013 06:15 AM
    Hi, I am trying to build a mobile application using Mobile Designer and have used generics in my code. When i first tried to run “Activate Handset”, it gave me an exception saying the source is JDK 1.3 which does not support generic. I modified the file bs-defaults located in /Tools/Build/BuildScript/v1.0.0 as follows
    But now I am getting the following error
    HttpConnectionHandler.java:318: cannot access java.lang.StringBuilder
    [javac] class file for java.lang.StringBuilder not found
    [javac] init_url = conn.getProtocol () + “://” + conn.getHost () + “:” + conn.getPort () + init_url;
    BUILD FAILED
    Is there any other file I need to change to make the app compatible with java 1.6 or higher.
    Thanks
    Rizwan
    #webMethods
    #mobile
    #Integration-Server-and-ESB
    #webMethods-General
