Hello community,
I'm currently facing some roadblocks in integrating Instana with our edge computing infrastructure. The aim is to optimize monitoring and performance insights across our edge devices using Instana's capabilities, but we're encountering some integration hurdles.
Has anyone here successfully integrated Instana with edge computing setups or encountered similar challenges? I'd greatly appreciate any advice, experiences, or best practices that could help troubleshoot and overcome these integration issues.
Specifically, here are the key challenges we're encountering:
Establishing a reliable connection between Instana and edge devices in diverse geographical locations.
Managing and analyzing data from multiple edge nodes within Instana's monitoring interface.
Ensuring real-time visibility and performance insights across the edge infrastructure.
If anyone has insights into configuring Instana for edge computing environments or has successfully navigated similar integration challenges, your input would be immensely valuable. Any suggestions on optimizations, potential configuration adjustments, or effective monitoring strategies for edge setups would be incredibly helpful.
I'm eager to learn from your experiences and expertise! Thank you in advance for your assistance and guidance!
Melissa Hankins
