After installing ACS 1.1.9.4, connecting to machine running v7r3, most things work.
Things that don't work are:
Schemas. If i click on that link, I get an error message saying, "SQL State: 38501, Vendor code: -443, Message: [CPF3EC0] Add relational database directory entry failed. Cause.....:See previously listed messages in the job log for the cause of the failure. Recovery....:Correct any problems and try the request again.
I believe the above message is caused by the difference in the machine name and the name listed in the DNS and I'm not sure how I can resolve that.
Content Assist. When accessing Content Assist from Run SQL Scripts, instead of getting a list of columns or fields within a select statement, I get a list starting with MAX, MIN...
I have reviewed the configuration for the connection, I have the latest version of Java installed.
Would it be better if I installed IBMOpenJ9?
Thank you.
MaryAnn Martin
