We have updated gettext-0.21-2.aix7.1.ppc.rpm, and zlib >= 1.2.5-4.
Original Message:
Sent: Mon January 09, 2023 05:45 AM
Subject: Not able to connect via Curl or wget when using https in URL, while able to connect via http.
Hello SANGAMESH,
We have downloaded the latest wget rpm package from this link, copied it to the server and install it.
https://www.ibm.com/support/pages/node/883796
- We used command mode to install wget rpm package
rpm -ivh wget-1.21.2-1.aix6.1.ppc
- wget rpm package failed to install because it requested some dependencies
- We installed only libiconv rpm package also and again try to install the wget rpm
package. The wget package installation is complete.
- After Installation, We checked the wget version and getting below
We didn't install libgcc rpm packages, We only install libiconv package.
Kindest Regards
Prajai.KN
PRAJAI K N
Original Message:
Sent: Wed January 04, 2023 04:43 AM
Hi Prajai,
How you have installed the latest wget ?
Did you install libgcc also along with wget
SANGAMESH
Original Message:
Sent: Mon January 02, 2023 11:07 PM
Hi,
We have upgraded the wget from 1.9.1-1 to 1.21.2, but now it is giving some different package error while connecting http or https.
root@#######:/ $ wget https://quest.iib.gov.in/questsvc/service.asmx
exec(): 0509-036 Cannot load program wget because of the following errors:
0509-022 Cannot load module /opt/freeware/lib/libiconv.a(libiconv.so.2).
0509-150 Dependent module libgcc_s.a(shr.o) could not be loaded.
0509-022 Cannot load module libgcc_s.a(shr.o).
0509-026 System error: A file or directory in the path name does not exist.
0509-022 Cannot load module wget_64.
0509-150 Dependent module /opt/freeware/lib/libiconv.a(libiconv.so.2) could not be loaded.
0509-022 Cannot load module .
root@#######:/ $ wget http://quest.iib.gov.in/questsvc/service.asmx
Could you please suggest
Kindest Regards
Prajai.KN
PRAJAI K N
Original Message:
Sent: Tue December 20, 2022 12:05 PM
You are using age old curl and wget. Probably published in 2002-2004 time.
SANKET RATHI
Original Message:
Sent: Wed December 14, 2022 11:26 PM
Hi Team,
Can we get any suggestion on raised issue.
While putting https it is not working.
PRAJAI K N
Original Message:
Sent: Tue December 13, 2022 04:53 AM
Hello,
Need help on resolving the issue of not able to connect via Curl or wget when using https in URL, while able to connect via http.
Error is as below while command execution.
root@#########:/ $wget https://www.google.com" title="https://www.google.com" href="https://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">https://www.google.com
https://www.google.com:" title="https://www.google.com:" href="https://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">https://www.google.com: Unsupported scheme.
root@#########:/ $ wget http://www.google.com" title="http://www.google.com" href="http://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">http://www.google.com
--15:13:06-- http://www.google.com/" title="http://www.google.com/" href="http://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">http://www.google.com/
=> `index.html.10'
Connecting to ###########:8080... connected.
Proxy request sent, awaiting response... 200 OK
Length: unspecified [text/html]
[ <=> ] 16,441 --.--K/s
15:13:06 (252.89 MB/s) - `index.html.10' saved [16441]
root@#########: $ curl -v http://www.google.com" title="http://www.google.com" href="http://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">http://www.google.com | head -1
* gethostbyname_r(2) failed for www.google.com" title="https://www.google.com" href="https://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">www.google.com
* Closing connection #0
curl: (6) Couldn't resolve host 'www.google.com'
root@########## $ curl -v https://www.google.com" title="https://www.google.com" href="https://www.google.com/" rel="noopener noreferrer" target="_blank" class="fui-Link ___m14voj0 f3rmtva f1ern45e f1deefiw f1n71otn f1q5o8ev f1h8hb77 f1vxd6vx f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f9n3di6 f1ids18y fygtlnl f1deo86v f12x56k7 f1iescvh ftqa4ok f50u1b5 fs3pq8b f1hghxdh f1tymzes f1x7u7e9 f1cmlufx f10aw75t fsle3fq" tabindex="-1">https://www.google.com | head -1
curl: (1) libcurl was built with SSL disabled, https: not supported!
SYSTEM DETAILS WITH VERSION
My OS version
7100-05-08-2114
SSL Version
openssl.base 1.0.2.2101 COMMITTED Open Secure Socket Layer
openssl.license 1.0.2.2101 COMMITTED Open Secure Socket License
openssl.man.en_US 1.0.2.2101 COMMITTED Open Secure Socket Layer
SSL)
SSL)
RPM version installed.
rpm -qa
atk-1.10.3-2.ppc
bash-doc-3.0-1.ppc
cairo-1.0.2-6.ppc
cpio-2.5-1.ppc
expect-5.32-1.ppc
freetype2-2.1.7-5.ppc
glib2-2.8.1-3.ppc
gzip-1.2.4a-9.ppc
libpng-1.2.8-5.ppc
libxml2-2.6.17-3.ppc
pango-1.10.0-2.ppc
tcl-8.3.3-1.ppc
unzip-5.51-1.ppc
xft-2.1.6-5.ppc
zip-2.3-3.ppc
wget-1.9.1-1.ppc
bash-4.2-2.ppc
bzip2-1.0.2-4.ppc
conserver-8.1.7-2.ppc
expat-1.95.7-4.ppc
fontconfig-2.2.2-6.ppc
gettext-0.10.40-6.ppc
gtk2-2.8.3-9.ppc
libjpeg-6b-6.ppc
libtiff-3.6.1-4.ppc
osinstall-1.0-1.noarch
sudo-1.6.7p5-3.ppc
tk-8.3.3-1.ppc
xcursor-1.0.2-3.ppc
xrender-0.8.4-7.ppc
zlib-1.2.3-3.ppc
curl-7.9.3-2.ppc
curl-devel-7.9.3-2.ppc
AIX-rpm-7.1.5.33-19.ppc
Request to have a look and suggest any action.
Kindest Regards
Prajai.KN
PRAJAI K N
